Rookie
AAH, I see now what the problem is: This is for the lanier 30%...The lanier 1/4 is built entirely differnet and yes, it was known on the first run that it had a soft wood gear problem. I was worried that you had a gear problem with the 30%...Now that that is cleared up I can rest easier. If you look in the arf forum it has many links to your 1/4 scale gear problem.....
Tom
