RE: Matrix fuel lines
the fuel tuping you can cut it reroute it whatever it dosent matter just cut it the right lenght you will need.make sure you start leaning it in a little bit at a time at about the second tank or what ever the instructions say, and you could have a bad glow plug that is pretty common when breaking in a new engine will it run if you leave you igniter on it and ween you take it off it dies if so its your glow plug hope this helps.
Dennis
Cen racing, TQ fuel
