RCU Forums - View Single Post - Sig Smith Miniplane build
Old 10-15-2006 | 01:20 PM
Rv7garage
My Feedback: (10)
Default RE: Sig Smith Miniplane build
Here is the firewall epoxied to the fuse. Getting the motor mounts into the correct position was a lot easier that I thought it would be. I temporarily attached the mounts to the engine (O.S. 52 Surpass), temporarily attached the firewall to the engine & mounts, then used triangles to position the whole assembly over the plans until the crankshaft was exactly centered on the plans in two dimensions. I marked the mounts' position on the firewall, and drilled and attached them. Sounds more complicated then it was.
Here is the framed-up fuselage...
