stripped servo gears
hi,today the stock servo of my matrix stripped gears after following the manual to tighten the servo saver with 6mm of thread exposed.the car came from factory with about 4mm of thread exposed.with 6mm the spring is so tight that the servo saver is not even working.what is the disadvantage of a loose spring on the servo saver.is the stock servo really crap.thanks
