RCU Forums - View Single Post - FS One by Hangar 9
Old 10-15-2006 | 04:00 PM
  #265
MSelig's Avatar
MSelig
Default RE: FS one by Horizon Hobbies
ORIGINAL: AraTidwell
I installed FS One. Very awesome physics. Only flaw I can find is in knife edge flight. Doesn't seem to generate enough side lift. Other than that, perfect flight characteristics. Could use a few more aircraft... hopefully that will come soon.
(Very) Glad to hear that you like the physics. If you want to tweak
the side force (using the editor) I can outline some steps
to do that.
There are more airplanes than you might be aware of.
In addition to the airplanes in the default list (first category),
there's a second category that includes variants of the 30 or so
originals. There are over 70 additional variants (airplanes) in FS
One. They range from a 3-inch span Aerobird Xtreme to an electric
ducted-fan park flyer BVM Bobcat jet up to many full-size airplanes like
the Ultimate aerobatic biplane with a constant-speed propeller just like
full-scale. In each case, the Scaling Wizard scales the model size,
mass, propulsion system, aerophysics, etc. Everything is automatic, but
you can selectively override the auto-scaling and change the airplane
weight, motor, propeller, etc to your specifications to match a known
model or create an entirely new airplane based on one of the originals.
There's now a new FAQ item that includes the full list of ~70 variants:
I heard about the 30 plus airplanes and helis in the sim, but where are
the 70 extra scaled variants? (Q1021-FS1, 10/15/06)
http://www.inertiasoft.com/fsonefaq/#Q1021-FS1
Michael
