RCU Forums - View Single Post - Official HPI MT2 Thread
Old 10-15-2006 | 07:58 PM
  #8069
46u's Avatar
46u
Default RE: Official HPI MT2 Thread
Put after run oil right in to the venture and not the fuel nipple as if you put it in the fuel nipple it could affect the o-rings on all your needle adjustments. When I but the after run oil in mine I take out the glow plug put 2 or 3 drops right in to the cylinder and 2 or 3 drops in the venture then turn the engine over. Put the glow plug back in put a couple more drops in the venture and turn it over again. I have found unless you put to much after run oil in my engines start easier after using after run oil because has a little more compression and lubes everything well to make it turn over better.
tattguy12 When I change the engine is my Savage I am going with a STS .28 for two reasons. One I hope to race sanction racing and the biggest engine you can run is a .28. Two normally as the engines get bigger in size means a longer stroke and normally makes the RPM lower which gives you less top end but does give you more torque. One other thing on the STS I recommend sealing the engine before you install it. I have an STS D21B for my buggy I am going to break in next week.
I forget who it was on here having so much trouble with there T-15 and if you remember I said I had one I was working on for a friend that we could not get tune properly. Will I sealed the engine and it is running better then it ever has!
