ORIGINAL: Artisan
ORIGINAL: map11
Mine has NO pump ......
It has no pump, yet it runs with the needle valve closed? Or am I mixing up two different posts?
Correct, This os 91 fs surpass has NO pump and high end needle fully closed its still a tiny bit rich..... its not a new motor so i cant return..... if i put the high end needle 1-2 turns out from fully closed i doubt it would even get off the ground.
What are we overlooking, has to be something simple, I wonder if the hole the high end needle stops up gets wore and bigger hole?
