RE: Air Hogs Aero Ace!
Yes, you do have to remove the solder bridge used for the channel selection.
Take care installing your switch making sure it doesn't interfere with the throttle and if you use a long nose pliers to tighten nut be carefull it doesn't slip or you'll damage the the switch.
