RCU Forums - View Single Post - Pot values?
Thread: Pot values?
Old 02-07-2002 | 01:51 AM
ReallyUglyStick
Default Pot values?
http://www.soldcentralfl.com/flyingpenguin/rcstick.htm
here's a howto on building your own box. the values for this setup is 150k, but it uses 1M ohm resistors. you need linear taper pots. the range the stick movement gives you is about 150k on a 1M pot.
