RCU Forums - View Single Post - Kelly's Brio build and pictures
Old 10-16-2006 | 02:45 PM
kregan's Avatar
kregan
Default RE: Kelly's Brio build and pictures
Enigine is now mounted and the cooling inlets are cut out.
I also mounted the wheel pants and wheels.
I mounted the engine a little sideways so the header pipe
would be closer to the pipe tunnel center line.
As it turns out I can reach through the front of the plane
and get to all 4 of the engine mount screws and remove the
engine, mount, and throttle servo as one complete unit.
Next I will mount the pipe once it arrives.
ID:	542162   Click image for larger version
ID:	542163   Click image for larger version
ID:	542164   Click image for larger version
