Foam glue
I don't know what your application is but I switched from using epoxy a while back and started using probond polyeurathane glue after reading an article in High Flight. I works very well at bonding and as it is a foaming glue the only worry is when sheeting with thin balsa sheeting you must make sure you use it sparingly.
