RE: inverted with a blade cp?
it is possible you are having a ruber band effect.....try just holding on to it, m,ake sure you got it good and the blades are clear and spin it up....add some negative pitch. See if the presure feels smooth or jerky. If it is smooth then I bet you are experincing a rubber band effect. Otherwise something is wrong....start diagnosis.
