Originally posted by flap
Im gonna get in trouble for this, but, IMO, the hinges will serve you better if you place them in the garbage can and get some Dubro hinges or something else.
I just put a new 4* in last weekend due to ca hinge failure, the ones which came with the kit. The hinges, 5 of them broke into on the elevator.
I wouldnt listen to anyone regarding ca hinge failure prior to the crash, I thought if anything went wrong it was due to improper installation.
If and when you completely disregard this advice, you must inspect the hinges prior to EVERY flight, dont do as I did and become complacent because theyre ok every time you check, sure as you do, youll miss the one chance you get, maybe, to save your plane.
I installed ca's on 5 other planes with no problems, now, I find out another club member just had the same problem.
Anything can fail!!!!
You hit the nail on the head regardless of the equipment used in any plane A Preflight check of the aircraft should be performed before each flight and an inspection on the bench should also be performed from time to time. All things can and do wear with usage and age!!!
BTW I saw a plane with pinned hinges loose an elevator in flight.
so rather then blame this type of crash on faulty equipment use it to institute a more detailed inspection of your aircraft before and after flying. Even then there will be no garrantees that you won't loose a plane due to a mechanical failure in flight. You will however know that you did everything possible to discover it prior to flying. Then it becomes a matter between you and Murphy
