RCU Forums - View Single Post - aileron servo idea
Old 10-16-2006 | 06:20 PM
daveopam's Avatar
daveopam
My Feedback: (9)
Default RE: aileron servo idea
I have several servos mounted the way you described. I have not noticed the arms being to short. I do however use the longest 4 sided arm that comes with the servo. Maybe your mounting the servo to low. I do mine as follows. I make the servo cover out of ply. Then use two hardwood blocks to mount the servo on the hatch. I have the side of the servo case right up against the hatch. Then I mount the hatch to the wing again using hardwood blocks and servo screws.
David
