Question about CA hinges
I've used Sig CA hinges for years and never had one pull out or break. I've also never drilled a hole.
I've been putting off using the CA hinges with the slit, as I didn't know how they'd hold up. I watched one of the most aggressive flyers in our club throw around a Pizazz with this style hinge. If they work on his plane, then I figure they'll work on almost anything.
Come to think of it, I don't really see much of a time savings with CA hinges. It always seems like one or two gives you fits. Also, the CA seems to run everywhere and turn the covering white. I'm trying odorless CA this time, but at $10 a bottle, I think I might go back to the pinned hinges. I never glued the pinned hinges, but used toothpicks instead. The straw idea with epoxy does work great though.
Robb
