RCU Forums - View Single Post - Question about CA hinges
Old 01-20-2003 | 04:45 PM
  #32
MinnFlyer's Avatar
MinnFlyer
Default Question about CA hinges
Sands,
Yes, you definately screwed up, but it's not too late to use the hinges. This fix will be a lot easier than replacing them. Just epoxy them into the wing, then drill a tiny hole through the trailing edge and the hinge and epoxy a round toothpick into the hole and sand it flush when dry.
