RE: GLOW push prop?
The prop is reversed. Look for props called "Pushers"
Also note: A pusher prop needs to on the engine "Backward" - that is, look at the prop, determine which is the leading edge and trailing edge. The leading edge faces toward the engine and the trailing edge faces the prop nut.
