Originally posted by phayd
Why does everyone mount direct plugs to their battery? I charge through the starter ports, since they are a direct line to the battery.
If your talking about the ports on the power panel I think people are afraid that charging through the ports will damage the power panel.
If you look at the power leads they will go through the panel if the switch is on and may do some damage to the panel since your charge source is now going through the panel and to the battery.
I also have a seperate charge port
