RCU Forums - View Single Post - NEW 1/24 VS tiger I exposed!
Old 10-16-2006 | 09:19 PM
Planedev
Default RE: NEW 1/24 VS tiger I exposed!
The other thing you can do instead of cutting teh tabs will be to add a little solder either to the positive tabs on the tank or on the batteries itself. I solder some AA rechargable packs b4 and the trick is to use a fine sand paper to sand the area you want to add the solder to on the battery tab and it will take solder after that.
