RCU Forums - View Single Post - GLOW push prop?
Old 10-16-2006 | 10:27 PM
B.L.E.'s Avatar
B.L.E.
Default RE: GLOW push prop?
One more thing, putting a standard prop on an engine backwards will not turn it into a pusher prop unless you also reverse the engine's direction of rotation, which is usually not practical unless you fly electrics or reed valve Cox engines. Pusher props have a reverse pitch so the engine can run in the normal rotation and have the prop push.
If you take a nut off a bolt and put it on backwards, you still have to turn it the same direction to tighten it. Likewise, if you install a tractor prop backwards, it still pulls, rather inefficiently though.
