RCU Forums - View Single Post - RAM 750 Operators Help!
Old 10-16-2006 | 11:02 PM
jetflyer's Avatar
jetflyer
Default RE: RAM 750 Operators Help!
"Where do you get an extension for the RPM lead?" -----> I made my own by splicing the wires and adding some new wire. Soldered each joint and used heat shrink tubing on each wire then a few bigger pieces around the grouped wires.
Glad to see you are getting better starts. Come to think of it now I believe I still get some popping at idle but nothing that I've had to worry about. As soon as I bump the throttle it seems to go away and it is smooth after that all the way to full power and back.
JR
