RCU Forums - View Single Post - Cessna with to much Power?
Old 10-17-2006 | 12:50 PM
CGRetired's Avatar
CGRetired
Default RE: Cessna with to much Power?
The OS 61 weighs in at 23.6 ounces with the muffler. The OS 46 (not the LA) weighs in at 17.2 ounces with the muffler. That's an extra 6 ounces of weight that you may have to compensate for. Additionally, the OS 61 would use a larger prop than you may be able to use on that aircraft (ground clearance). If so, and if you go for a smaller prop, you could spin that engine to bits with over-speed.
I had an OS 61 on my Tiger 60. I played with props and almost destroyed the engine when I went to a smaller diameter than it called for. It screamed.. for sure, but I got nothing out of it other than a lot more noise (not good).
You are probably better off sticking with the recommended size for that plane. Save the OS 61 for something larger... like a Tiger 60 <GRIN>.
DS.
