RCU Forums - View Single Post - Do fly it or not?
Old 10-17-2006 | 02:52 PM
  #34
skiman762's Avatar
skiman762
Default RE: Do fly it or not?
No it needs to be fixed because when he deploys the flaps the system will be in normal flight mode and drive the control way past its limit when using the ailerons and then there will be bigger problems
differential is simply to setup with flaperon differential adjustment this is NOT the way to do it on a plane with flaps
