RE: Setup for Spectrum DX6 and Blade CP Pro
Holy Helli,
So I have had my first very successful flight with the CP-brushless-g9gyro-spektrum upgrade I did. I used your base settings and had to change a few things, and some of it by complete trial and error.. But I managed to get it off the ground and instantly feel the difference. First off, the machine has a lot of power. Secondly with very little trimming, I managed to actually let go of the toggles for oh about 2 - seconds. found I needed to do very little put to keep it on the fence. However it is going to take some more tweeking as once you did throw it a little ie: circuit I could feel some holes in the plan as it were.. So I will just play from here and fine tune, once I find a setting I like, I will post it for you to compair.. mind you different machines..
thanks for your help!
cheers'
Sean
