How do you know your savage is shifting?
I agree with Ram. You can't miss it. If you are stuck in first the engine will not spool up to full RPM. The gearing is just a bit too low. My set screw keeps wandering, I think. Because for a while I was stuck in second the whole time. If you are stuck in second then you will not hear the tranny shifting and the engine will spool all the way up.
LT
