ORIGINAL: maukaonyx
Thanks for the input so far! I have not used a multibolt prop nut like that on the BCMA. Does it weaken the props by drilling holes into the props to mount them? Jon
You don't have to use the multibolt feature on the BCMA. I am only using the center bolt. If you feel that your prop is slipping, you can use two or more of the outer bolts, as well. My 40CC, so far, works well with only the center bolt.
Andy
