RE: BVM 91
Dan,
If you are determined to go with the BVM powerplant there are two ways to address your pipe concern. You could heat up and bend the BVM pipe. That might take a few iterations to get just right.
I had the same concern with asymmetric thrust that Shaun mentioned on my F-4. The pipe blocks most of the area of one of the exhaust cones, so most of the thrust comes out the other side. You can offset this with a bit of rudder trim. My solution was to use a Weston Mini-pipe.
The Weston pipe is about 9 inches long so you do get exhaust residue in the rear ductwork, which is not a big deal. The performance was very good with a BVM 81 engine. I have no experience with a BVM 91 and Weston mini-pipe, but it should work fine. If you want to try it I still have the Weston pipe and can give you a good deal on it.
Joe
