RCU Forums - View Single Post - Yet another tuning question...
Old 10-18-2006 | 03:07 AM
drksky1056
Default Yet another tuning question...
Ok, I've done the searching, but apparently I'm still too dense to figure it out.
Which needle affects which? High affects low, or vice-versa? Should I adjust the high or low first?
I've been fiddling with my Brillelli 40 and it seems, on the ground, the transition is always good. I had the low needle less than one turn out today and I fear that may be too lean. I did eventually hit a spot where it didn't want to idle any more, and I backed away from that point. At that point, the transition was solid on the ground, but once I got it up in the air things were different. When throttling down on a downline, the engine is still idling well, but sputters when going back up on the throttle. It finally died on one of these manuvers and I had to deadstick it. Am I still too lean on the low?
When tuning, do you make all the adjustments on the ground, or make an adjustment, see how it reacts in flight, land and adjust again?
Thanks in advance.
