RCU Forums - View Single Post - OS 46 running Backwards
Old 10-18-2006 | 08:21 AM
rhk
Default RE: OS 46 running Backwards
The engine is probably flooded. Try closing the needle valve and once the engine fires, let it run dry, and then start all over again i.e . open the needle by 2 or 2.5 turns.
The other alternative is once the engine fires, backwards, open and close the throttle rapidly. Very often the engine corrects it self.
At times you can flick the propellor in the opposite direction.
Hope this helps.
