RE: Substitute for Ether
Treven,
Lean runs arent the only source of high heat, extreme frictional pressures also cause heat build up, this is particularly true in our diesels at the wristpin and to a lesser extent the bigend brg, places that Andy has found to fail in some of his tests with no/low lube fuels. So to say the benefits of castor arent relevent outside of lean runs is a misconception.
Re the other uses of castor, it is widely used in go karts and other competion 2 strokes as well, its non use in automotive 4 st's is due to its natural ability to form larger molecules , which over a short time would cause the oil to become a solid,but research is being done to stabilise vegitable oils for use in automotive 3st motors due to the looming shortage of mineral oils.
Stewart
