RCU Forums - View Single Post - OS Max 46FXi
Thread: OS Max 46FXi
Old 10-18-2006 | 06:58 PM
boat1779
Default RE: OS Max 46FXi
Well I spent some more time with it this evening. I was running some K&B idle bar plug in it. I went back and found an OS 3A plug that the prior owner had in some stuff. Put it in and it ran much better. Started to lean out the high end mixture and things got better. Have leaned out the low end just a tad and now it runs continuously at WOT and idles. Seems as though the plug could not stay lit through my rich settings (and wrong plug?). It still does not have much compression and is hard to get started when hot. Does not pull fuel in at all just hand flipping the prop.
So what now? Send it in anyway since the offer is on the table, or run it like it is?
-thanks
