RE: CORO CUB Build Thread
Well, I jumped to the elevator for a quick second. I bend a 4-40 rod to make a U channel that I will push in the hinge area as you can see that will make the elevator operate nicely. I just measure the widest area from hinge to end of elevator and bend a 90. measure accress to the widest area on other side and bend another 90. Works great. Mikee says I should mount the control horn straddling the rod but I think I go to far out to make this happen. Any thoughts out there! I just slowly push the 4-40 rod throught the flutes slowly so I don't push one out the side. (Yes - I did it once.)
I can now cut the center of the elevator further in and just leave 1 or 2 flutes .
