Rob, on my "Do" #2... Here's my almost info
.. on the tanks.. I did not fill test,
but it did look bigger than my stock tank... I had to trim the tank saddle and I also
had to trim/shave the bottom of bulkhead at the???>> Tank access hole to get the
tank in the nose.. The tank ends just about even with the bulkhead that the wing
dowel goes into.. But.... one problem
... I forgot which tank I actually got... I
really think it was the 12oz... But??... Both have the same dim.. H= 2 1/2 W= 2 1/8
except the L, 12oz is 1/4" longer.. 4 3/4 to 5"... I just checked mine and it looks
about 5" long.... This is from Towers... And its was either the Sullivan RST 10
(300ml= 10.14oz) or RST 12(360ml=12.17oz) I believe I got the RST 12... My stock
Tk. had printed on it 270cc(9.13oz)... You can check the conversions... But..........
Even if it does hold more fuel (Mine does)............. I still had/have a bunch of "out of
fuel" dead sticks [:@]...... But the "Do" floats" Great
.... But remember... in a 2-3'
hover>>> out of fuel>>> dead stick..... And....... As good as she is.........................
The "Do" does not float that good....
My Bat's are a charging.... [
].... Not the "Do" but three of my "others"... Just in case
the forecast is correct on the wind......
