Hello,
When running the servo test, my 9253 t/r servo jumps. All the other servos slowly move from one endpoint to the other. As the 9253 moves to the left, it speeds up slightly just before it gets to the endpoint. When it starts to move back to the right it jumps from ~ 10% to 40% of the total travel back to the opposite endpoint. I have disconnected the control rod to no avail. When I turn off the power and rotate the servo by hand, it seems to move freely back and forth. I have set the 401 gyro travel screw to min and max and everything in between to no avail. I have the delay set at 0, the direction normal (reverse on the radio), and DS set to ON. I've only burned 3 gallons since I bought it. I recently crashed though and I can't remember running the servo test since I first put the heli together.
Any ideas
