RE: OS 46 running Backwards
Once the high-speed needle's properly-set for best running, any problem of the engine starting backwards is a result of starting technique and not the needle setting. Basically, you'd have to over-prime the engine to get it to start up backwards. As the engine gets more running time, it will likely lose the tendency to start backwards.
[edit for typos]
