There are limiters on the OS 46 FXi also,if it has not already been removed.The i in the FXi signafies that it is a remote needle for the high end adjustment.Be sure and remove the piece of fuel tubing running from the remote needle to carb and inspect for pin holes by stretching hose in your fingers.They are bad about getting a pin hole in that area even if it hadn't ran much.
