RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 10-19-2006 | 01:33 PM
  #5530
raideron's Avatar
raideron
Default RE: U-Can-Do 3d 46?
Hey Rob.... They are all numbered[:@].....
This guy at the field has 2 of them that he wants to sell... $80..... I'm thinking about
it... That's almost what it'll cost from ebay with their higher shipping??? But I may
just fix my V2...???? Not sure why, but it's still laying in the spot that I dropped her
at.... Bad me....
Had a Great morning, The S.T. did great.. I moved the bat. back a bit more, and also
finally added my 1/4oz of weight to the Rt wing, since I got more YS stickers to cover
the hole... I still need to touch the stick for level invert flt, so it may be going back
a bit more and I still need to do something with my tailwheel.... She almost lost the top
of the rudder[:'(] I did a 2' invert pass, and the gallery was yelling lower.... So.........
But just before, I did a few blenders..... Then I did the pass.... Forgot I was still on high
rates..... She came close[X(]... As the wind was doing all sorts of things... But all came
out great.... My Avistar did good also... Had to check all since our funfly is coming
up and I'll most likely use it... And my SPAD is still the fastest. But I'm losing ground..
We all had a "Big" surprize, we all thought the model was history... But the member that
instructed me when I started, went up in a (not sure what) 3 d type plane... But it started
glitching Bad!!! He has flown it before with no problems... Anyway He tried 3 times to land
after regaining control, but then it went crazy again, but luckily on the fourth try, he was
about 3' up at the start of the runway, and it went sour again, it did a tight circle and back
down the runway, and he had enough control to land and kill the engine with no damage...
