ORIGINAL: CPPROMAN
.... I incorporated -50% travel on the pitch ....
Kieth,
I really did not run it long with the stock TX about a week or two as I was still just learning to hover so I never got a good feel for the stock TX.
Are you flying a CP or a CP Pro? What are settings for throttle and Pitch?
I have been tweaking my settings as I get better plus I have extra shims in the head a gyro now.
It's odd that you said the 65 was a low head speed over the companies 70 (should be barely noticeable) I'll have bump mine up to 70 and see if I can tell a difference.
The pitch settings I'm running give me the full +12 and - 12 degrees pitch when I tried the 55 the company used the servos would bind on the ends pretty bad.
I'm wondering if there are different servos or software or something as when I ran those settings it was sluggish (I'm even thinking about tweaking the settings more to make my CP Pro even more responsive).
