RCU Forums - View Single Post - Cessna with to much Power?
Old 10-19-2006 | 11:08 PM
RCVFR
My Feedback: (7)
Default RE: Cessna with to much Power?
ORIGINAL: Arrow IV
Ruger,
That 61 shouldn't be a problem, in fact I think that's a better choice (especially since you already have it). The fuel tank will not be a factor, the airframe won't know the difference you can pull just as many G's with a 46 as a 61, beef up the fire wall with a little epoxy, move the battery back in the fuse and you might not have to add any weight.
I have a Flip and it calls for a 2 stroke 46 and I got a OS 91 4 stroke hangin out there!! No problem at all. I beefed up the firewall, moved the bat back and works great. I'm gettin about 10-12 mins out of it (stock fuel tank).
Besides your not adding that much weight and the 61 and 46 are similar in power out put, besides 4 strokes sound cooler anyway!!! JMHO
The OS 61SF is not a 4stroke, but a 2 stroke and a darn good one that deserves to be on a 60 size airframe. A Flip and a Cessna 182 are significantly different airframes. What's good for one may not necessarily be good for the other.
