RCU Forums - View Single Post - tuned pipes
Thread
tuned pipes
10-20-2006, 01:03 AM
3
rcflyer1970
My Feedback: (
212
1 Post
RE: tuned pipes
Here's a baseline chart I use, make sure you measure from the glow plug to the widest point of the pipe as the exhaust flows (not a strait line) I normally go with the next higher pitch on the prop than I plan on using then trim the pipe a 1/4 inch at a time until there is no more rpm gain, then run the prop with a little less pitch or cut down a bit and see how it performs, if the plane has alot of drag small speed props won't pull it well
Reply
Like
rcflyer1970
View Public Profile
Send a private message to rcflyer1970
Find More Posts by rcflyer1970
View iTrader Profile
