RE: tuned pipes
Two things to remember when cutting 1/4" lengths of header to get the desired top end out of the engine. The first is that the shorter the header, the sooner the engine will come onto the pipe. The second is that the shorter the header, the lower the temperament of the engine; it will be more sensitive to high end needle valve changes.
