RCU Forums - View Single Post - Chicken Sticks - Why?
Old 10-20-2006 | 01:55 AM
  #51
Lloyd
Default RE: Chicken Sticks - Why?
I've never owned an electric starter for a model airplane. Had my fingers whacked a couple times. But, never a bad cut until I started using APC props. I did alway use a rubber finger protector from Ace R/C. But, that's all chewed through now, thanks to the APC sharp trailing edges. Anone know where I can get another?
I'm not sure how relevant Methanol flash points are. The platinum in the glow element acts as a catalyst to begin the fuel burn with the residual heat from the last combustion cycle. For starting, the red hot glow element excited from battery current is more than enough to start a methanol burn under compressed conditions I don't know how cold it has to be before ignition is prevented. But, I remember starting glow engines in the middle of winter with temps in the low 30s, just with the glow battery and finger proping. These were .049 and .35 engines on 15% nitro.
The flash point issue IS relevant to spark ignition IC engine that don't have a catalytic element. Also, you'll find that in winter months, E-85 gasoline is more like 70/ 30 instead of 85/15 for precisely the reason of cold starting.
Cheers,
