RCU Forums - View Single Post - 2 cycle oil debate
Old 10-20-2006 | 10:42 AM
  #78
Tired Old Man
Default RE: 2 cycle oil debate
After about a year of hard running they will have developed some soft carbon build up but it's pretty much a wipe away thing if desired. Piston wear has usually only been notable when foreign object injestion has occurred. Not using an air filter means anythng that gets sucked into a carb makes to the inside of an engine, so small scratches happen from time to time. As in any other engine there will be light "scuffs" on a piston where they arc a tiny amount inside the cylinder during directional changes.
