Os Max .46 Fx - Rust
There are only 3 major moving parts in that engine that can develop rust. The front and rear bearings and the crankshaft and its still possible that you have not run the engine completely dry each day since it often takes a number of attempts to run it dry and it still seems to always have some fuel residue left in the crankcase. Adding a good dose of a proper afterun oil followed by a good prop cranking should prohibit the formation of any rust. If you are seeing a brown coating of sorts on the insdide it is likely to be a castor residue which often forms on the back of the rear bearing cage and sometimes on the crankshaft.
Try and scrape off some of what you feel is rust and take a closer look. I think you will find its a somewhat paste like castor residue and nothing to worry about.
