RE: tuned pipes
Well I flew the Meccoa last week with the pipe on and it flew ok, but didnt get on the pipe like I thought it should. Since this is my first pipe experience and the Meccoa was given to me I figured that if I was going to burn up a engine I might as well use that one.
After I get it right, I want to pipe my OS .50 sx on a Dago Red.
Ok, guys with all the info. After cramming my brain and reading your suggestions and going to the Jett website.
I figured that if I can't get the engine too rich I may have a fuel flow issue.
SO.... I drilled out the carb fitting to 1.3mm to 2.0mm, changed the fuel lines to 3.6mm, drilled out the pressure fitting to 2.0mm.
Gee, too bad it is going to rain tomorrow.
Larry
