RCU Forums - View Single Post - 2 cycle oil debate
Old 10-20-2006 | 09:49 PM
  #86
Tired Old Man
Default RE: 2 cycle oil debate
If you have a reasonable mix ratio it doesn't matter if you flood the engine or just shut it down at the end of a run. It will be well lubricated either way. Try doing it the other way a time or two and then let the engine sit for a week or three. Then check the cylinder wall. There will still be plenty of oil there.
No big difference either way, so why not go with the noisy way?
