RCU Forums - View Single Post - Air Hogs Aero Ace!
Old 10-21-2006 | 04:15 PM
  #3556
FERNDALE AIR FORCE's Avatar
FERNDALE AIR FORCE
Default RE: Air Hogs Aero Ace!
Hi all, unless your buying the entity to mod, I don't recommend it. It is using a nimh battery and can't generate enough power to overcome the weight. The control is also particularly poorly designed. My biggest beef however is that they didn't use the correct hardware on the props. A prop nut came off in flight. Prop nut and propellor are somewhere in the yard. This is the first air hog I've had that is nose heavy. If they put a lipo in it and redesign the controller this might work. The motors are really noisy as well. Back to target it goes. Tim
