RCU Forums - View Single Post - Substitute for Ether
Old 10-22-2006 | 01:15 PM
  #457
chevy43
Default RE: Substitute for Ether
Don't forget that FLYING your mix may not be the same as bench testing as can be seen by looking at the repair on the wing of my Big Stick. Also ( may be obvious ) throttling is much harder. If it wasn't for throttlling I could probably run a straight diesel oil mix.
I can see there are so many different goalls going on in this thread, eitherless, alternitive oils or no oil, cheap cost, most "green" fuel and easyest to make and obtain.
I went for cheapest and easyest to make-obtain and I feel like I met those goals and have a very flyable mix. Now that Andy has given me another good idea to try I will use a bit of WD-40 and see if it can replace the Amsoil cetain booster and make it easier yet to obtain and cheaper too.
Treven.
