dave0101_again
The Debonair is a great trainer; very forgiving. Although it is a fairly easy build, you might want to get some assistance if there is an experienced SPAD builder in the area - lotsa little tricks and techniques that take a little while to master. The HOR (Hell on Rails) is an easy build, but might be a bit of a handful as a first trainer. It can be built with a Debonair style wing which should be a great flier. The HOR doesn't use gutterpipe for a fuse; just aluminum channel.
In addition to the SPAD forum at RCU and
www.spadtothebone.com , you should check out
http://spadworld.net/ and
http://www.rccombat.com/forum_2000/f...sp?FORUM_ID=22
Have fun
Ross
