RE: Extra 300 Prototype #2
Then "cover" the holes...
The small piece in the center is 1/8" light ply and will be the front of the cannister tunnel. It will also be where the throttle and choke servo's are mounted. You will also see 1/4" sq light balsa which the cannister floor will later be glued to.
